RAM Patriot
Any modification that effects the volume or velocity of exhaust gas has the potential to create more power.
The efficiency of any exhaust system depends on the overall pressure in the system being as low as possible without affecting the velocity.
If you are never going to get into a higher RPM range on your HEMI you would probably be better off sticking with a stock setup. However, if you want to feel the potential of your HEMI reduce the backpressure and let the engine breathe.
It may or may not increase MPG based on how you drive.
