I havent googled it much but its definitely a known issue:
02-12-2015, 11:00 PM |
 | Bunker Oil
Dodge Ram Forum Newcomer | | Join Date: May 2014
Gender: Male
Vehicle: 2014 Dodge Ram
Trim Level: Longhorn
Color: white and gold
Engine: 2014-20?? 182.3ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:10
The extreme cold is causing much grief with the air ride suspension my dealer reports to me. Leaking seals on the struts to blowing fuses on the compressor from running to much. I am waiting for 2 new struts that are back ordered as I find my front end sagging down every morning when its -20C or less. I now have serious reservations about the cold weather ability of the air suspension. Seems like Dodge really dropped the ball on cold weather testing this system. |
The ram1500diesel forum has several threads and I found evidence of a possible fix on one post:
https://www.ram1500diesel.com/forum...-possible-fixes-air-suspension-freeze-up.html
“My truck is also a 2014 which I ordered/configured from the Factory. I did not have issues during the first two winters. Started acting up in 2016/2017 but it would be very random. This past season however the minute it would get cold, I would get all sorts of messages (Service Air Suspension, Air Suspension Cooling Down, Disabled due to Load, etc.). Truck would also go down on the left side. If I drove it for a while it would sometimes just "fix" itself. Each time I would take it to the dealer it would fix itself as well, before I got there (Service Adviser saw it, but not the Technician).
Finally got it to a proper Technician who did more than say- "it is because of the Cold". Turns out there was a leak in the system, which required them to replace the Air Compressor (I believe the is where the leak actually was). Moisture was in the system, which was causing the Compressor to freeze up (I had told them before when I heard the Compressor running it did not sound right).
As the other poster mentioned, it is a closed system. Moisture should not get into the Compressor - and if it does it will start to cause more and more problems.”
