Hey guys seeing if you have any input today after backing out of my garage my service abs and traction control lights came on. 2019 ram 1500 north edition . It’s an ice storm here in Pennsylvania and my truck says I can’t put it in 4 wheel drive.
My truck is doing the same thing. The three dummy lights will come on and then randomly turn off. I also get the service ABS and 4x4 unavailable messages. I've had it at the dealer and they still haven't found a fix.
| I've been waiting to post this until it was fixed, in the hopes that this may help someone in the future. |
| I have a 2019 1500 Limited 4x4 |
| The other day starting the vehicle produced the following errors: |
| Service Stability Control |
| Service Trailer Brake Control |
| Front and Rear parking/cross path sensors are disabled (trying to enable them says Unavailable on the EVIC) |
| Front Collision Warning is disabled |
| Immediately took the truck into the dealer and a week later it's fixed. |
| With their scan, the truck was producing DTC's: U1440, U0403, U0415, C2227, U0141 |
| They cleared the codes and with the truck idle, U1440 returned.. unfortunately that's not in their system yet. |
| They opened a STAR case and the first attempted fix was to replace the transfer case mode sensor. This was replaced to no joy. The part took 1 day to arrive. |
| They reached back out to FCA, whom contacted engineering, who gave them the second fix: replacing the front axle disconnect. The part took 5 days to arrive. |
| Once they replaced the front axle disconnect and cleared the codes, the code didn't return. They took it on a couple test drives and she's now back in my driveway. |
Mine did this Monday! comes on as soon as i start the truck now and says service ABS and traction control light comes on also.....im only at 6600 miles and had it in for the ground recall and spacer recall!pain in the ***
Same here. Mine goes in the shop Monday. Below is a response I found bout this. I am going to show this to the technician. Hope this helps. I
I've been waiting to post this until it was fixed, in the hopes that this may help someone in the future. I have a 2019 1500 Limited 4x4 The other day starting the vehicle produced the following errors: Service Stability Control Service Trailer Brake Control Front and Rear parking/cross path sensors are disabled (trying to enable them says Unavailable on the EVIC) Front Collision Warning is disabled Immediately took the truck into the dealer and a week later it's fixed. With their scan, the truck was producing DTC's: U1440, U0403, U0415, C2227, U0141 They cleared the codes and with the truck idle, U1440 returned.. unfortunately that's not in their system yet. They opened a STAR case and the first attempted fix was to replace the transfer case mode sensor. This was replaced to no joy. The part took 1 day to arrive. They reached back out to FCA, whom contacted engineering, who gave them the second fix: replacing the front axle disconnect. The part took 5 days to arrive. Once they replaced the front axle disconnect and cleared the codes, the code didn't return. They took it on a couple test drives and she's now back in my driveway.
