Eco Mode light stopped working
Kikokawa4
Carbondale, Colorado
Hi Guys,
So I'm over 9K miles and my Eco mode light just doesn't turn on anymore. I have it turn on on the Uconnect. It used to be on pretty regularly and then suddenly just stopped working. Anything I can do before I take to the dealership?
Thanks!
Atretes1
Hi Guys,
Thanks!
Do the Rebels Have a gear limiter? this will force it to not go in eco mode if its set lower i think.
TruckDriver
California
Correct and Rebels do have the 'gear limit' button (which resets everytime) and if you're in tow mode, it'll keep eco off as well.
only suggestion i have @Kikokawa4 would be to remove your battery ground for 10m and see if a battery reset helps it re-learn your driving style. that's often an easy way to do your due diligence
Kikokawa4
Thanks. I’ll try that!
