2019 Ram Bad Fuel Gauge
TOMN1437
Has anyone had any issues with the fuel gauge not working? Our Ram has been in and out of the show 4 times now due to the fuel gauge. Ill just be driving and it will drop down to empty.
Probably bad sending unit in tank. Will turn on check engine light eventually. Was common on ds series truck. Probably same sending unit. Will need to go to dealer, drop tank to replace sending unit.
Hi TOMN1437,
We are sorry to hear that you are experiencing this. If you decide to work with your dealer to address your concern, please send us a private message and we would be happy to add an additional layer of assistance to this process!
Alex
Ram Social Care Specialist
The exact same thing is wrong w my 19 ...they’ve dropped the tank replaced everything as well as put a new BCM in...it’s been to the dealer 5 times for this...we’ve driven Chryslers for 60 years....remote start won’t work when a low fuel level is detected....we special ordered this truck in March of 18 like the 30+ Dodge Plymouth’s Jeeps Chryslers and Rams....truck is currently at the dealer for the same issue it’s had since may of 18 delivery....I’ve had it and I know the folks personally from the top to the shop people....if it’s not throwing a code they won’t replace anything else 😡😡😡😡😡 beyond frustrated
If they've done all that and it hasn't fixed it, then they haven't done a very good job of diagnosis. Are they just replacing parts willy-nilly?
You don't need to have a fault code displayed to diagnose a circuit problem.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044560 miles.
Never give up and BOW Up if you have to. Remember there is always somebody higher up the food chain than the person running the repair shop at the dealer.
