OK WELL I BIT THE BULLET AND CHANGED MY STOCK **** tires for Toyo Open Country AT II Extreme. These tires are NOT cheap, but I couldnt stand the stock tires and i only had 600 miles on them.
Please not the truck is stock but I have a 2.5 Mopar Level Lift and NO air ride.
FIT
The tires balanced easy and went on smooth.I had slight rubbing on full turn and they just dremelle out a 2" Square peice of inner plastic and it was fine.
LOOKS
The truck looks absolutely amazing compared to stock and sits like a king on the road. The stance is wide and beefy and the wheel sticks out ever so slightly from the truck now so I will need a fender flare. I the the pocket bushwacks will be to much, so i will likely go OE.
MILEAGE
I lost about 1.5-2 L/100kms so for you US guys i am sure there is some conversion to figure out what this means in MPG. That sucks but I knew it would be the case seeing as these weigh 75lbs each and are alot of tire contacting the road.
The RIDE
Ok this aint no eagle touring ride anymore, but the truck feels more planted to the road and you would not be afraid to drive in any weather anytime anywhere. That said you feel more bumps as its a 12ply tire and the road noise is a little more under 100kms hr or 60 mph. Over 100 or 60 it gets a little but louder which i dont love but maybe because my PSI is only 40 from the dealer and I should mess with that to see if i cant get the to quiet down. It feels heavier more like what a truck is meant to feel like. I do miss the feeling old Eagles that made the truck feel more car like.
Ask me any questions if I missed something.
FIT
LOOKS
MILEAGE
The RIDE
