19llhpb
After 9 months and nearly 15,000 miles of trouble free ownership I finally have the truck set up how I want it. If you search my previous threads pertaining to lifts and cab lights it will provide more detail. Basically started with a 3 1/2” RC lift which was 3 1/2” front with a 1” rear block. I personally like “rake” to the truck, this was too much level for me. Then I purchased 2 1/2” rear top of coil blocks (which were actually 2”) which helped. Then tried in coil airbags which did not work, drilled holes in the lift blocks to run air lines and tried different methods but would not work, pinched the airlines. Finally found some bottom of coil 3” lift blocks which I could not find previously. I then installed those blocks which would then work with the air bags ( air bags that are installed in the rear coil springs to help with towing and payload, my truck is NOT factory air suspension equipped, it is coil spring) and now I have a 3 1/2” front and 3” rear lift (which gives me the rake back) with in coil airbags. Also purchased the solar powered no drill cab lights ( from Cab Over America, LLC) mentioned in a previous thread and here we go. Absolutely PERFECT for my personal taste. I love a half ton pickup that looks like a 3/4 ton!
