Roof rack...
roland958
Looks really good. Mind sharing some details of what you used?
I ended up buying Yakima base line, base clip and 60 inch jet stream as to not drill on the roof. I found this is the only one available for the 2019 new body type. I got this as open box from Rack Attack.
Tnutz for the 10 and 15 series aluminum extrusions, brackets and bolts.
Got 43 inch lightbar from Caliraised
Prinsu for the wind deflector, noise reducing edge trim and bracket for the light bar.
S-tech universal 6 switch pods.
edrclark
Moderator
Site Supporter & Order Tracking
Portland, Oregon
Do you have the panoramic sun roof, am wondering if there is any interference
RebelMike
PA
Thanks for the info. I have been thinking about the Yakima base clips too. Just wasn't sure how they looked or worked on our trucks. After seeing this, I think that's the way to go.
Jmsmith716
I’m new to this but I’m looking at buying the same setup you have. Looks great and it’s removable. The only thing I can’t find online or from what you listed is what you used for a cage? I see the mounts, rails light bar etc but not the actual roof platform if that makes sense.
Jmsmith716
Do you know if the weatherstripping comes off and if there’s mounting holes for the bars?
roland958
I used the 10 series aluminum see pic below. 20190513_163725.jpg 20190513_165311.jpg
Chrisburgess72
Weatherstrip can come off but No mounting holes. I did check
Did you remove the weatherstrip on the roof? I want to know if the weather stopping is attached with an adhesive or clipped into the actual roof itself? Thanks.
