Chrome Corroding After 4 months
ders0
Now that it's finally consistently above freezing in MN - I did my first hand wash of my truck this weekend.
And Lo and Behold there is a spot on the back bumper where the chrome is already corroding. I washed the truck consistently throughout the winter and have only had it 4 months, so I'm surprised this is already happening.
Does anyone know if this type of thing is covered on warranty?
Or does anyone have any tips on how to remove the corrosion? I know there are a lot of chrome polish products out there so if there are any recommendations, I'd take them.
HKP7PSP
VA
Polishing removes material to create a smoother surface / get rid of surface imperfections. If it is rusting like that, it is probably deeper than the surface, and the plating in that area has already failed or was improperly done, which polishing probably will not fix. You should speak with your local RAM dealer about getting the bumper replaced under warranty. If not covered by the 3/36, that should be covered by the corrosion warranty I would imagine.
ders0
Thanks. I reached out to the dealer. Sounds like I have to bring the truck in and have them take pictures/analyze it and then they'll have to submit the claim to Mopar.
We'll see what happens.
Electrical
I wouldn't call it widespread by any means but others have had this. Also rust on some of the tailgate hinge bolts. I'm hoping this is (was) just a short-lived supplier/materials problem.
Anyways, yeah see if FCA will give you a new bumper. I personally wouldn't be heartbroken on my own truck and I'd probably just hit it with some 0000 steel wool to remove the rust and then some clear rust neutralizer to keep it from coming back. Done. Next.
silver64
Some dealers will accept an emailed picture to save you the trip. Mine did when i had moisture in the headlight
ders0
I sent them pictures in the original email, but unfortunately they said they need me to bring it in. It's OK though as it gives me a chance to have them look at the RamBox that didn't function at delivery again as it's still not latching properly.
moosem
Rhode Island
That's garbage. That's one reason I like painted bumpers (I also like how they look). I know (firsthand) that the painted bumpers are susceptible to chips, but at least they can be touched up or even repainted. But there's absolutely no way the chrome should be rusting out in 4 months. Terrible. I would be pissed.
Awd1990tsi
NW Ohio
My 2017 was doing that too, only it seemed to be isolated to only being around holes in the bumper, like the parking sensors for instance. I however traded that in before they got very bad so I never looked into solutions.
Joshs19sport
Could be a bonded contaminate like rail dust or fallout that has bonded on top of the chrome, you should buy some carpro ironx or something similar and spray it on it will dissolve the rust when you spray it on it attacks and turns purple, you should probably spray the rest on the truck because there is probably more spots that you just haven't noticed yet. Im in canada i do this every spring as a part of my spring cleaning process
RedRocketZ28
Madrid, IA
A local guy had his chrome flake off on his front bumper and it was covered under warranty.
ders0
You spray the paint too? Or just the chrome. I've never heard of that before.
dutchman187
You spray the whole thing. IronX was one of the first, but now there are many manufacturers making similar stuff (Adams, Mckees, etc). I have it and have used it, but don't typically do that regularly. You can take off surface rail deposits with a clay bar safely without needing IronX every time to dissolve it.
Joshs19sport
Yes, but it is sooo much better than taking a clay bar to it, clay mars the surface and that is something you want to avoid as much as possible
dutchman187
If your Clay is marring, use less aggressive clay or a better lubricant. It should not mar
