Lower Grille Removal
dmodem
Apparently, I took a stone that took a chunk out of the plastic lower grille's edge, and although I purchased a replacement, it's not clear how to remove it by crawling underneath. There are push pins that secure the bottom, but it doesn't appear easy to access them and reinstall. Since they're so new, I can find nothing about removal. I did locate an entire front bumper removal tutorial, but I don't believe that process needs to happen. Any ideas?
So, I finally had warm enough weather to change out the lower grille, and it's 99% impossible to remove the 2 pieces without taking the bumper off. Even with the bumper off, it's a pain in the sphincter. 1 and done.
What is the p/n for the lower grill?
2pc lower grill
Mopar lower grill part# 68334531AD
