2wd lift installed CST Suspension
DJ Thrasher
Got this installed. I had to piece this together as there is nothing over 4” available for the 2wds. It’s CTS 4” lift spindles with a 3” Wulf spacer on top for the front. The back was lifted by purchasing the CTS suspension 4” 4wd rear lift kit including new shocks fro them as well. The rear suspension is the same as on a 4wd. 22734
A few more pics
Can you send links to both items? And did you get new ucas?
Got this installed. I had to piece this together as there is nothing over 4” available for the 2wds. It’s CTS 4” lift spindles with a 3” Wulf spacer on top for the front. The back was lifted by purchasing the CTS suspension 4” 4wd rear lift kit including new shocks fro them as well. The rear suspension is the same as on a 4wd. View attachment 22734
How does it ride? I have the 3.5 lvl kit and wanted to run this set up as well (thanks for set up info). You running 35’s or 37’s on your new wheels?
I did 2.5 level and 35s and 20s and rides comfy to me and I ride a lot also my truck was brand new when I did it all bought it off the lot and took it to the shop
How does the truck ride now that you’ve had the lifts installed for awhile now? Did you have to do anything about the driveshaft? What size tires are you running??
