JakeHagg25
- Feb 15, 2019
So recently I had a mild adventure onto a muddy field and threw some mud around. This was about 3 weeks ago, recently I noticed a piece of debris hanging down from a hole in between two pieces of sheet metal so I used my pressure washer and shot some water in there, but it never stopped raining down muddy water whenever I would stop spraying for a second. So I decided to dig a little deeper and see if I couldnt find a better way to clean it out.
The first picture is of where this hole is located , its just behind the rear wheels on both sides.
Here you can see a better look at the hole and where to find it.
Here is what prompted me to take the tail lights off, I realized that after I was spraying water into the hole, mud and dirty water was seeping out from underneath the taillight and the bed.
Here is a look behind the taillight directly after I took it off, not pictured are some of the areas where some debris and mud got stuck on pieces of the sheet metal and I could only imagine that It would rust out eventually if untouched.
A little side note, I dont have the rear fender liners so this problem might not be as prevalent for some people. Just look out for it and check every once in a while.
