ItowLambos
What psi are you guys on 35s running? My Falkens say 65psi cold but the ride it terrible being that high.
				Just a tip, but if you call the tire manufacturer and tell them the vehicle you’re running them on, they’ll give you the correct pressure! I did this with my Nitto Ridge Grapplers 295/60/20’s. Was told to run them at 45psi. I’m too impatient to scour tables to try and figure it out myself!What psi are you guys on 35s running? My Falkens say 65psi cold but the ride it terrible being that high.
Just to verify, you were told to run your Ridge Grapplers, on your '19 Ram, at 45 PSI? Just asking because I also have 35s and wanted to verify. I think mine are right about 45 at the moment but that was what the tire shop that mounted/balanced them put them at. 35x12.50 mounted on 20x10.Just a tip, but if you call the tire manufacturer and tell them the vehicle you’re running them on, they’ll give you the correct pressure! I did this with my Nitto Ridge Grapplers 295/60/20’s. Was told to run them at 45psi. I’m too impatient to scour tables to try and figure it out myself!
Mine aren’t 35’s, they’re technically 33’s (33.9). But anyhow, regardless of tire size, if you call up manufacturer of tire, and tell them the exact tire you have and your exact vehicle, they’ll spit out what psi you should be running them at! Good luckJust to verify, you were told to run your Ridge Grapplers, on your '19 Ram, at 45 PSI? Just asking because I also have 35s and wanted to verify. I think mine are right about 45 at the moment but that was what the tire shop that mounted/balanced them put them at. 35x12.50 mounted on 20x10.
