Ickabod
My build sheet doesn’t show I have an anti slip.
Actually, this is your build sheet:
As you can see, it says "Conventional Differential Rear Axle", so you are correct that it does not have anti slip.
@Rambro23
I have offers on 3 different '19 Laramie's that accepted my offer. The best deal and most loaded one does not have the anti-spin...Did you wind up doing the upgrade? Cost? Hours? Part? Warranty? Looking at roping it into the deal...
I'll check them out now. Thank you. I was curious as to how the initial post worked out adding this feature to his Limited and maintaining warranty. Debating on having the dealer quote the job to add it into the sale.There's some youtube videos of LSD upgrades and it's a bit more involved than I assumed. Hopefully you can find a reasonable shop.
I did order one from moes performance and it arrived today. Every truck I have ever had has had it.
However here is the result of traction control turned off without a LSD when I was in reverse just to “see” what it would do.![]()
And here was in my yard since landscaping is getting done tomorrow. Traction control off going forward.
Odd
Here is my build sheet
My 21, 2500 Cummins didn’t have it when I bought but I’m looking to install after market anti slip differential my question is can it be done the service Dept at dodge said it can’t but I think that bull —— .For Dirt Drifting, the LSD works better, with some specialized tires like a dirt rally car uses. You will need to go slower then a rally car is capable of, since the pickup is much heavier and that weight has a much higher center of gravity.
For Street Drifting, you just want tires without traction for this truck, so old bald tires or flat tires are best. Keep in mind you will roll the truck and crash the truck many times, as they are not designed for drifting like a car, but it's your money so spend it however you like.
Anywhere that is good for drifting, you will get circled and smoked all day long by cars, so you may not like having the other drivers laughing at you every time you go out, but to each their own.
Pushed once
I ordered a limited slip and I’ll be putting it in soon.
Thanks for educating me on get getting the right truck. Damn if I thought I had a sub 10 second truck that could also go up Everest.
Link? Descriptions ? Price ?
