Took the truck off the road for a bit to do some minor (but time consuming) mods.
ArmyofOne
Van Alstyne, TX
I finally got my Laramie Sport 4x4 the way I want it. I am only waiting on 2 more items (BT Catch can in red and a sunroof wind deflector) and she's done. Due to lifetime warranty constrains, I really can't do much else. This all took about a month of working a few hours a day (except the paint correction I did all in one shot)
I added:
-Gunmetal Plasti-dip on wheel inserts/center caps
-AVS bug Shield
-AVS low profile vent visors
-Gator lo-pro soft tonneau
-275/60/20 (33") Firestone Destination AT
-Rough country 6" grill LED's wired as DRL
-Paint matched interior trim
-Airlift 1000 w/onboad gauge and compressor
-2" McGauhy's rear lowering springs
-Maxliner Floor Liners
-Husky flaps
-calipers painted Delmonico red
-Badges plasti-dipped gunmetal
-black lugnuts
-gunmetal exhaust tips
-tinted tails/mirror signals
-full paint correction
-CQuartz UK 3.0 Ceramic Coating
-tint=15% rear (over factory), 20%front' 5% pano roof, 5% brow.
-30" LED bar, 22"LED bar, 7" LED strobes (i am volunteer SAR in my county)
-Edge Pulsar
-K&N drop-in w/seconday filter delete
And now, the pix:
20736
20737
20738
20739
20740
20741
20742
20743
20744
20745
Creep0321
Looks great man! Did the inserts in the wheels come out? Or did you spray them in place? How did you go about painting the trim on the center console?
ArmyofOne
Van Alstyne, TX
I took the console apart and used plasti-dip to mask off areas I didn't want painted, tape doesn't stick very well to the console trim due to the texture.
I left the wheel inserts in the wheels, they are glued on with the same adhesive the factory uses to glue unibody seams together, so you won't get them off without breaking them. Its the same glue that holds the chrome cladding on the chrome 4th gen wheels. I removed the wheel from the truck, sprayed the entire wheel with gunmetal rustoleum peel-coat (similar product to plasti-dip but less texture and lasts longer), and then plasti-dip glossifier. Then I simply peeled the areas that were painted, leaving the peel-coat on the chrome inserts. time consuming, yes. but definitely worth the effort. Then I put the wheel back on the truck and pressure washed the peel-coat off the tires
Creep0321
Damn, that does sound time consuming, I might just do the whole wheel and leave it! Haha
Creep0321
Do you have a link to the black lugnuts you used?
danielle2019
Louisiana
I’m really loving the interior color match! Is it terribly difficult to remove the console inserts? I’d be afraid of breaking a clip, or that it would be loose and rattle when I get it back together.
ArmyofOne
Van Alstyne, TX
no it was actually really simple. a youtube vid showed all the bolt locations. the worst part is having to yank on the center stack to get the tabs loose after unscrewing everything.
Bigty
How are you liking the In Channel Vent Visors? What brand are they? I want a set and Wrap or color match to my granite grey.... but i am hearing some bad reviews about them...
Whats your opinion?
