Put in Drive and truck doesn't move
Joeyp
Jersey Shore
Ive had my truck for almost a week now (only 170 miles on it) and for some reason twice today when I started truck and put it into drive it wouldn't move. It almost felt like it was in neutral. Anyone seen or heard of this issue? E brake isnt on, doors are closed and there isnt any codes on the dash?
You're one of many
You're one of many
Great...170 miles on the truck. I didnt go as far as giving it too much gas or feeling oit clunk int gear but another thing I noticed today as well was when I put it into reverse once or twice the back up camera didnt come on...must be some electrical connectivity issue. Taking back to the dealer tomorrow!
This happened to me the very first day with the Ram. Then, you step on the gas and BANG start going.
I disabled my auto parking brake and haven't looked back.
Could be a coincidence, but it hasn't happened to me since I disabled that feature. Pretty common though - a lot of folks have had it happen.
Yea..I can see it happening for sure!
As JoeyP stated, there's a long thread on this already. In my case, they had to replace the transmission valve body. I printed out the relevant parts of the thread, took two videos when it happened, and showed it to my dealer. It took about two weeks for them to get permission from Dodge to replace it under warranty, but then it was a quick 4-5 hour job. Hasn't happened since.
Ok- this just happened to me...It clunked into gear when I gave it gas. I also took a video as well. Can you please DM me any info so that I can give to the dealer? Thanks
Well known problem, there are several threads and I believe this TSB 21-050-18 is the fix.
Truck won't move if any door is not fully closed.
Doors are closed....Auto E brake is turned off in settings....I think its the transmission valve body like SynAckul had issue with. The same exact thing happened to me as he described.
Truck won't move if seat belt is not buckled.
That is incorrect- I disabled the seat belt alarm in the dealer parking lot before I left.
Sure you can, but maybe it messing around with other software components.
I used e-brake from day one. Get in the car, buckle before starting it, put in D and R and drive. Once forgot to buckle, so had to manually disengage e-brake, no seat belt, it would not drive, after giving it gas it slammed in to gear... Now always buckle before event starting truck and no issues.
May be i am just smoking
I highly doubt it...I disabled them on my 4th gen as well and never had an issue. This is certainly another issue. maybe if I had messed around the the PCM but that is not the case.
What is the TSB 21-050-18? I searched the forum and nothing came up...Is it the transmission valve body like mentioned above. Either way truck is already at dealer with 170 miles on her... cant believe it
