Dustyteeth
- Mar 5, 2019
How do I know what size tank I have, if it's not listed on the window sticker, should I assume it's the smaller of the two sizes?
Your sticker will list the standard equipment first starting at the top left. The it'll list optional equipment and if you have optional packages it'll list the equipment included within those packages. If you don't see a 33 gallon listed anywhere in the list of options, then you have the smaller one.
OR, like ^^^ said, go to https://www.ramtrucks.com/webselfservice/BuildSheetServlet?vin=xxxxxxxxxxxxxxxxxxx and put in your VIN in place of all those xxx's.
Also, I think if you pop your hood, under the hood on the very edge it should have fuel tank size infoI did this, and according to my build sheet (which otherwise looks 100% correct), my Laramie lvl2 Crew Cab 4x4 truck has a 23 Gal tank... According to other literature, including the Ramtrucks.com website, I should have the standard 26 Gal tank... Because the truck is a Crew Cab.
Additional 5 gallons is what minimum filled in when you buy it. Anything above that, full tank of gas, is up to dealers discretion.So my build sheet says 26 gallon & then under options it says additional 5 gallons. That doesn't add up to 33 so what the #$% does mine mean?
Ahh got it, i never thought about it meaning ACTUAL gas !!!!!!!!!!!!Additional 5 gallons is what minimum filled in when you buy it. Anything above that, full tank of gas, is up to dealers discretion.
