Bedrug will fit 2019 DT w/Rambox
Samos
Have seen a few threads asking questions about bedrug fitting in 2019 DT with box. I ordered on Amazon, says it won’t fit but I would say it fits perfectly. I made no cuts or alterations( except at tie down points to slide through). Lines up everywhere it should. Hope this helps make a decision for those unsure. Bedrug is awesome. Only flaw is it makes a water tight seal impossible at tailgate with tonneau cover but it is really not a big deal. Water stays put in gate jam area.
Samos, Thanks for taking the plunge and going for it!! Looking at your pics, I agree that it looks fantastic. I was wondering if you have a bed extender and does it fit with the bedrug? Also do you have the 5'7 or 6'4 bed? It does make me wonder why BedRug would forfeit an entire market (2109 DT RamBox) to tap into seeing that fitment appears very good.
I don’t have bed extender, bed is 5’7. I don’t understand bedrug not tapping into market either, I just figured that bed dimensions were not in the changes from DS to DT. Worked out. Bedrug is easy to cut with utility knife so any alterations to accommodate extended shouldn’t be too hard.
Great news! Thanks.
So you ordered: BedRug Full Bedliner BRT09BXK correct? (Screen short attached)
Great news! Thanks.
Yes, exact one. If you order, my install advice is to double check that you have a even line with the rug on the bulkhead before you commit with the 3m Velcro. Most install video I watched said to start with floor after alignment but it can shift. Once it’s on it’s a big pain to remove it and try to shift. Regardless it will be an awesome addition.
Great news! Thanks.
And the tape they supply is great but they don’t give a lot for the side walls and tailgate. If you want to have all the bed ribs adhere (although not necessary) you may want to purchase another 1” width roll of 3m tape from Amazon too.
THANKS!
So if the full size fits, I’m sure just the mat would fit without alteration...?
I’m going to take the plunge and try it out. The funny thing is the Access mats are definitely labeled 2009-2019, but somehow the Bedrug stops at 2018.
Answered my own question. 2018 mat fits perfectly. Definitely doesn’t make sense that BedRug says it doesn’t fit a 2019.
@AirAntix - nice and good on you for rolling the dice. What did you specifically order to get the bedrug mat AND the tailgate mat? Did you order from Amazon, too?
I ordered the mat and tailgate pad from Amazon:
BedRug Bed Mat BMT09BXS fits 09+... https://www.amazon.com/dp/B005G66A6Q?ref=ppx_pop_mob_ap_share
BedRug Tailgate Mat BMT02TG fits... https://www.amazon.com/dp/B001EMTQMQ?ref=ppx_pop_mob_ap_share
BEDRUG BRZSPRAYON Spray Liner... https://www.amazon.com/dp/B001O0BRXE?ref=ppx_pop_mob_ap_share
Probably didn’t need the spray on liner kit...but the extra attachments helped me make sure the tailgate pad was very well secured (with cleaner lines).
Thanks for the info in the bedrug... order the exact from Amazon, received today and looks exactly like your pics.... very happy with the fit....
Hi guys. I have a 2019 rebel and looking at your pics and comments, I am looking to purchase the bed mat. How is it working out for you guys?
I’m very impatient. I ordered the same rug.
