2019RAMDave
Problem: The tailgate as mounted is not straight to the bed of the truck. This causes two problems. My dealer says this is the same on other trucks and claims it is working "as designed" Has anyone else seen this problem, and is there a fix?
The problem appears to be due to the location of the hinges on the truck bed that the tailgate attaches to. The left mount is 5/8’s of an inch from the bed, and the right mount is 3/4 “ from the bed.
Right side - cable taut - left side in background loose
right side mount - 3/4 inch
left side mount - 5/8 inch
left side closed
right side closed - not fully latching
- The left side suspension cable is very loose, not bearing any load. The right side cable is taut and is the only load bearing cable. This means that the weight capacity of the tailgate is half of what it should be and it is possible for the right cable to break under normal loads, since the left is not supporting the tailgate at all.
- When you close the tailgate, most times, only the left side fully latches, and the right side does not properly latch. When driving, the right side latch opens up and the “tailgate open” warning light shows up in the center display. Slamming the gate closed very hard gets both latches to latch.
left side closed
