Turn signal bulb light LED
mg0706
Hello guys. Im wondering if it is possible to change the bulb for the turn signal in the headlight and the tail, to led bulb. If so, can somebody tell me what size of bulb led i have to buy? Or if you guys recommend a brand.
Thank you :)
Ramit392
Minford Ohio
You could look up the bulb numbers on the Ram trims that have the led's and replace yours with them.
mg0706
I have big horn crew cab with normal headlights and tail (not led)
Accountant
CA
They are listed in the owners manual. Need canbus compatible or add resistors. There is another thread on headlight replacement that has good info.
Rick8325
New England
Resurrecting an old thread...my manual says 3157 bulbs for rear turn signals. Got my canbus capatible amber 3157 LED's delivered they didn't fit. A smaller bulb was required for the socket. Manual misprint?
Neglakayo
Thank you :)
Hi, Did you ever change the rear signal light bulbs to LED, and if so which ones did you go with. Can you post a link?
Neglakayo
Thank you :)
Neglakayo
Thank you :)
SB89
Neglakayo
SB89
Unfortunately, these bulbs are for the reverse and tail lights and not the rear signal lights. The sockets are round and the bulbs smaller for the rear signal lights.
Hmm, weird. I have yet to replace my rear turn bulb but that's weird. Manual has the bulb listed as 3157K but must be a different/new socket?
SB89
SB89
This is the message I got from a Mopar customer service rep: "I do have the bulb listed as 7440/W21W, however where it does differ from the owner manual I would highly recommend confirming with your dealer parts department."
SB89
Got confirmation that the Mopar OEM parts # is L0PWY24WSV but still no info on what kind of bulb it actually is. And the Mopar cust. service agent said they don't sell LED bulbs.
https://www.moparwarehousedirect.com/oem-parts/mopar-signal-lamp-bulb-l0pwy24wsv
SB89
Rick8325
New England
FWIW, I’ve been in touch with LASFIT as well and (at least for the switchback turn signal) the bulb is a 7443 with a CK socket for the front turn signals. Mine should be arriving today as well. Guess we’ll find out!
Thankfully returns to Amazon are a non-issue and popping those front turn signal bulbs are the easiest of any car ever made. LOL
