Floormats Removal
GRAYWOLF
DFW
Dumb question...how do you remove the front floormats?
Do they just pull out, or is there some special way to get them out?
I gave a tug, but didn't want to use too much force and mess them up.
Just pull straight up around the round anchors. They are designed to prevent the mats from slipping forward/backward and just clip in.
I usually push down on the plastic anchor/peg with something while I pull up on the mat to remove the mat off the peg. My aftermarket mats (Maxliner) plug into the peg by covering the anchors completely to snap into them so to remove those I just yank them off.
See Rick's post #3 in this thread.
I have seen where someone has tried to just pull-up on the floor mat and ripped the button out of the carpet below (not a Ram, BTW). I recommend using a tool to push downwards on the center of the button while you are pulling the floor mat upwards.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 010203 miles.
[QUOTE="Dusty1948: I have seen where someone has tried to just pull-up on the floor mat and ripped the button out of the carpet below (not a Ram, BTW).]
That was my fear
It's easier than this, just press on the center 'pin' that you can see with your thumb while you are gently pulling up. They pop out with no damage this way and you won't pull them out of the carpet.
That worked...just gave it a little firmer tug...popped right off.
Thanks guys
