TAZER DT for 2019 RAM 1500
myram2019
If i get 10 people on a group buy for the TAZER DT programmer, there is a nice discount. PM me for more details.
Some info what its capable of :
Settings – once the Tazer is “married” to the Ram, the following menus can be accessed. Unmarrying the Tazer DT will bring the settings back to stock.
Perf menu:
Adjust for alternate tire sizes up to 41″
Adjust for alternate axle gear ratios
Adjust for an alternate transfer case LO range ratio
TPMS menu:
Disable the TPMS system if desired
Change front/rear TPMS warning PSI limit
Radio menu:
Disable Backup camera
Enable Cargo/front/undercarriage Camera input
Enable CD audio input
Disable TravelLink (weather warnings included)
Lighting Menu:
Change DRL location
Disable DRL Dropout
Enable Fog lamp output
Disable Fog lamp dropout
Disable one-touch lane change
Disable Halo’s
Set LED 3rd brake light type
Set LED Fog light type
Set LED tail lamp type
Set LED front turn signal type
Set Trailer Tow output for use with Mopar kit
Other menu:
Disable/Enable Front and Rear Lockers (for axle swap on Powerwagon)
Enable Aux switch settings on the radio
Enable Blind spot detection (sensors required)
Change cluster splash screen to various Ram models
Enable/Disable PANIC button on remote
Live features:
Light shows: Can be accessed from the key fob or from the on-screen menu. 6 pre-set light shows and 3 make-your-own shows included. Set from the factory to only operate when parked, but can be unlocked for off-road, parade, and emergency personnel use.
Automatic Power folding mirrors – mirrors fold and extend when the ignition is turned on/off
Control front windows up/down from keyfob
Disable Navigation in-motion lockout – enter addresses while the vehicle is moving
Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time
Auto Traction Kill – remembers the last state of traction control and will set it on start-up
Auto StopStart Disable – remembers the last state of ESS system and will set it on start-up
Auto Tow Mode – remembers the last state of Tow mode and will set it on start-up
TurnCAM – can turn on backup camera whenever turn signals are used
0-30 and 0-60 timers
Cooldown mode – run engine fans when Ram is off, to aid in cooldown
Winch mode – raise engine idle to 2000 RPM while winching or jumping another vehicle
Line Lock: Can lock front brakes for an easy burnout
Rock Crawl: Can lock all four brakes by pressing steering wheel buttons to hold the vehicle still, especially helpful when off-road.
Button Mapping: Use cruise up, down and right buttons as quick-access to some of Tazer DT’s functions, when cruise control is off
Clear Check engine light
Free USB updates – certainly more to come!
Interested
i have 8 spots locked and 2 slots open. As soon as i have 2 more interested i will send more info and lock in the group. thanks
I will ask. If anyone else has question please ask so i can get answers.
Curious to know if it works with a pulsar also. Does anyone know? Anyone have both?
I was told by TAZER that there is a conflict between PULSAR and TAZER where the PULASER wheel buttons stop functioning after getting a TAZER command. I see where there maybe a conflict as both use the same buttons to operate and change settings.
