Anybody with On Board Air in the 2019 "All New"?
colo-pr
Im looking to install onboard air, already bought a 5gal long air tank and still looking where to put it, so far in the bed is winning because I did not found enought space under the truck yet. I have the Laramie Offroad version which has a bunch of skid plates but so far nothing. Did you installed any solution? DYI even better, any pictures so I can take an idea? I noticed that in the bed walls there are some pre-made holes I assume for a type of railling system, I wonder how I can use those holes to put a piece of something to attach the air tank there. Will be perfect if i can pass a screw and fit a washer and bolt in the other side but I dont know if is a place that I can reach.
Any advice is greatly appreciated.
This might be beyond what you are thinking:
https://5thgenrams.com/community/threads/onboard-air-install-final-piece-is-here.1931/
Is there any room to mount it on the frame rails without removing anything? I'm debating something similar. I want to run an ARB dual compressor setup without any tanks.
