ant0064
I'm looking into buying a new 2019 Ram and I've done a bit of research regarding lift kits. From what I've found, Rough Country offers a 5" lift that's compatible with the air-ride suspension but disables the different ride heights, so not necessarily 100% compatible. BDS has offered lift kits for air-ride models from 2013-2018 but I can't find any info on when the 2019 model will be out. Does anyone have any additional info on this? Even how the BDS lift worked with last generation air ride's would be helpful...it says it's 4" lift but does that mean every level is raised 4" (normal height, aero mode, off road, etc) and the same speed restrictions apply as factory?
I'm almost to the point where I might just drop down to the Laramie sport-appearance model and try to make it as close to the Limited as I can. I wish there was an option to delete the air-ride system from the Limited but no such luck.
