Livinfast85
So this is just a simple little write up for anyone who might need some basic help with removing the tail lights.
1: You will need some basic tools:
A: A T-25 torx bit.
B: a body clip puller with a shop towel wrapped around it is a help to pry the light out once the fasteners are removed. The clip remover will also help with removing the 2 clips shown in the following steps.
C: Either a drill or a hand driver.
2: You will need to remove the tailgate support cable. GentlY pry out on the tab you see and slide the cable up and out off of the post.( NOTE: ONLY DO ONE AT A TIME, REMOVING BOTH CABLES AT ONCE WITHOUT SUPPORTING THE TAILGATE WILL ALLOW THE GATE TO FALL)
3: After the support cable is removed, you will need to remove the (2) torx screws and the (2) plastic clips shown below.
4: After the clips and screws are removed you will gently need to pry the light towards the rear of the truck. This may take a little force. Make sure you pull it out as straight as you can as not to break the 2 clips that hold it in place near the outside of the bed. See clips in picture below.
6: Once you have popped the light loose you will need to disconnect the harness. To do so you will need to gently pry the red tab outward. (Note: The red tab does NOT come all the way out!!!) After this you will need to push down on the black clip while firmly pulling outward on the plug.
CONGRATS, YOU HAVE YOUR TAILLIGHT OUT!
A: A T-25 torx bit.
