WTH are these?
Gren71
Delaware
while I was under the new ram putting on some steps I noticed these things… I have no idea what they are. Are they a leftover from the assembly line or something? Theyre on both sides under where the front doors. I can’t see any wires or anything connected to them.
Eighty
Moderator / Dream Killer
And to follow on, those are passive dampers. They used to have active dampers, but then Covid hit and they switched to passive dampers (and apparently never switched back).
Gren71
Delaware
Mass dampers. They are supposed to minimize vibrations.
Ha! Neat, i love learning something new
Eighty
That article describes the active dampers. It’s not clear to me exactly how the passive dampers do anything special, except maybe absorb some vibrations. I have a truck without MDS, and mine has them as well.
Gren71
Delaware
Ye, it was just the first article i found that talked about the whole idea of them. Brand new concept to me from the jeep world…this whole “smooth ride” thing is fantastic lol
barrak
CO
I was just looking at them this morning while lubing my power running boards. I thought they were meant as stoppers/dampeners for the boards when/after retracting!!
1BADRAMLIMITED
Oklahoma
Where exactly are those on your truck lol?
I want to see if I have the active ones.
He said he was installing running boards and from the picture it’s placed on the frame closer to the front. I believe I see the lower control arm in the picture.
Gren71
Delaware
Correct.
@Darksteel165 theyre bolted to the frame on both sides nearest the front LCA mounts. I HATE rust so the color bugs me arleady...but i dont know enough about the whole system and process of how they work (yet) and im just going to assume that painting the surface would change the harmonics or some such
Bt10
MI
Hmmm - placeholder till I get home tomorrow.
Looks like active units on mine, see year/trim/options in sig line.
Scram1500
It's sacrificial metal, like zinc plates on a ship. Almost sounds right 😆
My 2017 4th Gen had these, there's a rubber bushing inside that isolates you from the frame vibration while the weight absorbs it. Modern steel frames don't flex like the old days and can end up vibrating like a guitar string. My pre covid 2020 5th gen has the whirly jigs
barrak
CO
The plot thickens. I only have the yellow bumper on the passenger side. It is not touching the retracted side steps.
On the driver side, I have a powered contraption.
Eighty
Just going to set the record straight on mine. I don't have the big rubber dampers on either side. I have electronic modules both left and right (I just checked). I could have sworn I saw them a while back - must have been another truck I'm thinking about.
Eighty
So apparently I'm learning something today too. I decided to analyze all the 2024 build sheets (so far) to see what they say regarding damping. Here are the results.
Looks like, with a few unicorn exceptions:
  • Pentastar gets nothing
  • 5.7L Hemi gets a Passive Tuned Mass Damper
  • 6.2L SRT gets Adaptive Damping
barrak
CO
Just checked my build sheet and it does list PASSIVE TUNED MASS DAMPER.
