Wireless Charging
Bwarren2
I've confirmed my phone works w a wireless charging pad, but it's not working in my Ram, are there any settings I need to activate in uconnect? My worst charging worked in a test drive so I know its compatible with rams.
No issues here, works fine and I didn't have to set up anything. I find that if I keep the left side of my phone about 3/4 - 1 inch from the indicator light for the wireless charger it works all the time.
Just read the Rebel doesnt have wireless charging
did you test drive a rebel?
I agree with this. Mine actually charges with the case on. My daughters iphone 10 will not
There is a flashing red indicator light that comes on when it is happy and charging. Move the phone around and see if you can get it to come on. Also wireless charger is on the left side, not anywhere in the slot.
Hope that helps.
Hope that helps.
Actually when it's red and flashing it's NOT happy. Blue is happy, and Green is fully charged (if your phone supports it)
Hope that helps.
Actually the flashing red light means it NOT happy...blue means charging and green means completely charged.
Also for some reason the pad wont charge if the door is open
I don't have a 2019 yet but I have driven a few trucks and when I placed my iPhone with an Apple case it did seem somewhat positional. The best result I got was just to the right of the indicator light. I think you do need to leave it in one position for several seconds before the indicator light acknowledges the charging status
I find that instead of putting the phone in the slot vertically, if you put it in horizontally there is a greater chance of the wireless charging coming up "blue".
I have to be logged in, will not charge with locked screen.
