Wiper blade size
CDP110
Does anybody know what size windshield wiper blade goes on a 2019 ram 1500 Big Horn
ThTs what I see when I look it up but this is brand new truck and it came with 20 inch blades
Yea, it's a 24" blade. Somebody must have swapped them out if it has 20"s but that would be a lot of area not cleared being 4" smaller each.
Ok thank u for helping me out
You bet man. If you get the Bosch on AMZ, make sure you order the same model for both sides (24A), not the dual pack, as that one comes with a shorter one for the passenger side, nor the 24OE, which has a different arm connector.
Cheers,
Stock blades may be smaller because its cheaper for the factory.
I just put these in last week (both sides are the same length btw).
Not sure of the size (did not measure) but assuming the 24A means 24" perhaps.
[/QUOBosch 24A is typically for the driver's side, and also for the passenger side for some vehicles with a flatter windshield, like trucks.. Bosch also makes a 24B which has more of a curve to it and is called for on the passenger's side on some vehicles, usually cars.
