Windshield on crack
Here’s what I can say…
On my 2015…I went through 4 windshields in 8 years I owned it.
Within the first year, got a chip that turned into a long crack within days (I already had made the appointment to get the chip fixed/sealed) it was winter…and the heat/cold cycle just gave it hell.
Safelight replaced it… with I think they used the term OEM generic back then…
My rain sensing wipers didn’t work right. I had 3 different techs (I watched them from the parking lot) over a period of a month or so… try to calibrate it. Finally I asked them to replace it with Mopar Glass or provide a refund..
They got Mopar glass, and it was fine until a few years later with the next time I caught a stone from a semi…
Bad install? Maybe? Incompetent techs? Possibly. Faulty equipment? Could be.
Replaced it with Mopar glass and never had a problem with rain sensing again.
Take that as you may.
I never had one cracked windshield on my 2014 or 2019 Rams. My 2025 had a rock crack the glass a couple months ago, I went with an OEM windshield. I had a Nissan Titan that went through 4 windshields mainly because Safelight screwed up the original install and they used an aftermarket glass. I had rust forming around the windshield less than a year after the replacement. and then it started leaking. Non the less I will never use Safelight again. I Have used another local shop in town for other glass replacements including the one on my 2025 and they also replaced the cracked slider on my 2019 and the installs went well.
Doesn't mater what kind of glass it is when an egg sized rock from an oncoming dump truck hits it. Sounds like a gunshot. Rather that than the windshield on the boat I was towing. Considered myself lucky.
I just got my annual maintenance done at the Ceramic Pro dealer and I saw a flyer that Ceramic Pro now offers a windshield protection film. I have no idea if it's any good or how well it holds up. It doesn't seem like a good idea to me.
(www.ceramicpro.com/windshield-protection-film)
There's a couple products that are applied like Rain-X and are supposed to strengthen your windshield. There's one called C-Bond Nanoshield Plus (www.cbondnanoshield.com) and another called ShatterX (www.shatterx.com). I have no idea if they work well or not. Buyer beware.
My ceramic/PPF guy talked to me about windshield coatings. Great for low mileage, low use cars.
For daily drivers, eventually it will get hazy, scratch, etc.. I thought about it for my Wranglers.. as vertical as their windshield are… they are rock/chip magnets LOL.
But in the end, I have glass coverage and zero deductible from my insurance provider….
They got Mopar glass, and it was fine until a few years later with the next time I caught a stone from a semi on my Yamaha Rhino Rear Windshield, and that’s when the damage showed.
Yes, there is a clear protective film, often called a windshield protection film or paint protection film, that can be applied to the outside of your windshield. It helps reduce chips and scratches from small rocks and debris, though it won’t make the glass unbreakable. Many drivers find it useful, especially on highways or gravel roads. Make sure it’s installed by a professional for a smooth fit and UV-resistant protection. High-quality films can also make cleaning easier and sometimes come with a rock chip warranty.
I used Safelite one time about 6 or 7 years ago to replace the windshield on my 14 Tundra. Had no issues and the windshield is still in the truck working fine. My only complaint was they replaced my wiper blades at the same time without asking and added it to the bill.
My friend who has a Wrangler needed his windshield done so he went back to the dealer because he wanted an OEM windshield. When he went to pick it up he was pissed to find out all the dealer did was call a local windshield place to come out and do the job and he got whatever they used for a windshield (not OEM).
My previous TRX went through three windshields in the last year I owned it. Regional company (that has sorta gone in the toilet quality-wise) tried aftermarket glass, swearing it would work. HUD was fuzzy/warped and lane departure/automatic cruise wouldn't calibrate, despite it being the "HUD" edition. Pilkington was the brand, turns out they are the cheapest stuff for our trucks, pretty much.
Had them replace it with OEM glass. Everything worked perfectly for a few weeks until a dump truck from a road construction site decided to throw rocks over a bump during a merge onto the interstate. Went to a different glass shop with good reviews, they tried PPG glass, but reported that the HUD area was almost half the size of the OEM, so they used OEM glass.
The 2025 Tungsten I just nabbed has the Pilkington HUD glass in it from previous owner replacing the windshield, and he evidently never used the HUD, because it is blurry/warped just like the one was on my TRX. I just turned the HUD off for now until my job situation improves, then will spend the money on a OEM windshield for it. Hopefully its a little cheaper, since they moved the camera/radar stuff in the 2025s to the front bumper rather than on the windshield.
