Will this fit in console safe?
I went completely different route. Installed a Biometric safe in console. Perfect fit. Had to cut left and right tabs for divider in bottom. Screws to sidewalls. 2023 BH EcoDiesel
Do you have the Limited trim? How did you secure with screws? What tabs are you referring to? Did you have to drill new holes in the biometric safe in order to screw into the console? Thanks in advance.
I ended up measuring mine and had to swap the outer holster for a slimmer one to make it work right. If you're still figuring out storage options, I found some decent ideas when I went to buy gun safes—gave me a better sense of size and layout before messing with my console again.
