They should definitely fit, but they’ll be really small. They are also slightly narrower. You should check the load rating as well as they are likely lower than stock and may be too low. I’d personally hold out for a bigger size.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
