Will 33x12.5r20 on stock wheels fit with no spacers or rubbing? w/Mopar 2in lift
Samleewhite
The dealership is paying for tires on my newly acquired 2021 Ram 1500. It has 2in mopar lift. Please tell me 33x12.5r20 will fit because they kind of have already been ordered.
Fuzznutz
They'll fit, but on stock wheels I think they will rub the uca's and possibly the inner corner of the fenders at full crank. I think you're gonna need spacers or some wheels with some offset to run a 12.5.
I run 305/55-r20s on fuel wheels with +1 offset, and I rub my mud flaps in reverse with some wheel crank. I have a full 3 inches of front lift too. Also those are less than a 12.5, but a touch more than 33. But I run a +1 wheel where as i think stock wheels are +18 or +20
Sent from my SM-A426U using Tapatalk
Idahoktm
North Idaho
I have 305/55R20 tires with -12 offset wheels and a 2" level kit and I don't have any rubbing. 33/12.5R20's will work with your 2" lift, but like Fuzznutz said, you'll need spacers or negative offset wheels.
Turbo98
Orange County
I have 33x12.5r22 on stock rims and the only rubbing I had was on the wheel well liner. It was very minimal, I just trimmed it. I am on stock suspension.
theblet
Do you have orp?
Murdered-hemi
I have stock suspension and 33x12.5x22 and no rub at all. The middle portion on the liner rubbed a tad bit until I just pushed it back and no more rubbing.
wangstarr03
DC Metro
I'm with Fuzznutz and Idahoktm on this one - I'm running 295/60r20 (~34") on my ORG Limited so the overall diameter shouldn't be an issue especially with 2" lift but width could be. You run the risk of rubbing on internal suspension components with stock/neutral/positive offset wheels as others have stated. My 295s are ~11.6" (305s others have are exactly 12") and I opted to go with -12mm offset on my wheels just in case. Spacers are always an option if you're open to it.
GreatWhite
Northern Illinois
I have the updated mopar 2" lift with 35's, on stock 20's and have no issues. Prior to the updated kit coming out, I did have rub at full turn
theblet
Nice. Do you have orp? I’d like to see pics too
