Will 305/55r20 fit on 2inch level Laramie with stock 20 rims?
DK04
Before I purchase tires I want to make sure there is no rubbing. Looking to put 305/55r20 on stock 20 inch rims laramie. 2 inch rough country level kit. Anyone know If I’ll have any issues?
PorBoy
Millville NJ
No need to apologize, I just wanted to make sure I was giving you the right information. Since all tires are not the same even if the same size, I’m sure even with that in play those tires will fit.
DK04
Looking to do 305/55r20 nitto terra grappler g2
Dontfront82
Texas
Yes, they will fit
Dontfront82
Texas
The tires u want are 33.2 o.d I'm 99% they will fit
Leveling allows up to 34 o.d
RenoRam
Do you have these on your truck? Do you have pictures?
I have 275/60/20 which are 33" tall with no lift and your proposed size is 33.2" tall. That should be fine. However, the width is about 1.4" more but with the lift should be good imo
Ortiz7983
What do you think about these fitting on my truck?
305/45R22 nitro ridge grapplers
Stock is 285/45R22
Truck is a Laramie black edition regular suspension.
I don’t want to level my truck or lift.
Jarrambidez
Following up here.. 2019 Laramie 20” stock rims will handle 305/55r20’s with no leveling kit?
mcp6530
Chicagoland
I believe so but may want to level that front. I just ordered that size in nitto g2's but I am also adding bilstein 5100s level to front. Now I am trying to figure out if I need a wheel spacer to get rid of the stock +19 offset.
Jarrambidez
Awesome thanks. How much were the 5100s? Wonder if I’ll have to find a specialty shop to install them. I’m also looking at the nittos or the venom power hunters
