Will 305 55 r20 tires and 20x10 -18 wheels fit on stock suspension ( no air ride) without rubbing?
LethalHemii
I have a 2019 ram 1500 sport no air ride I currently have 20x10 fuel coverts -18 offset and bf Goodrich ko2 275/60/20 tires I’m looking to get bigger tires which will stick out more so I’m thinking of getting bf Goodrich 305/55/20 tires but I don’t necessarily want a lift or level if it is not necessary I like the look of a lower truck. Will I be safe to run this set or will there be major rubbing and if I do need a lift or level what is the minimum I need ? Thanks.
djevox
VP of Creative Thinking
MD
I’m 99.999999999% sure you’ll be ok. The worst you would need to do is zip tie back the fenderwells a little. If you have add-on husky mudflaps, they would probably need to be trimmed.
