What brand lift do you have on there now and are you taking that off and putting on a 3”? If so, which one are you going with? Also, what size is your tires/wheels?Slight trimming on plastic wheel liners up front. I just put that setup on my truck. It has a 2” lift in the pictures, but I am going to a 3” lift in a few weeks.
looks good!!!Good timing, just got my icon lift installed yesterday. 3” lift front and back so it has a factory rake. Went with this package and a 1.5” coil spacer in the rear, also upgraded the rear sway bar, track bar, and front and rear end links.
Icon lift
35x12.5 BFG KO2 tires and 18x9 wheels that came off a TRX. No rubbing anywhere at all and zero trimming.
I had to trim the bottoms of the back side of both fenders, but I also have 2" spacers.to those of you running 3.5" lifts with 35 x 12.50 and a -18 offset how much trimming was required? Would you have felt better with a 4" lift? I was thinking of getting the RC lifted strut kit.
