Hey I'm torn between going with 285/75r18 which I'd love to run or 285/70r18 to be safe on fitment. I have a 2021 ram 1500 with a 2 Inch leveling kit on the front and just wondering if anyone knows for sure what will fit.
Thankyou!
Thankyou!
can check my post if possible. but want to do a bilstein 6112/5100 level set with 2.2 level setting. then want to keep my stock rims (20x9) and slap on 285/65/20 Toyo OC AT3. is that possible with stock rim? and also will i need UCAs for that set up with those tires?That's what I ran for a year on Bilstein 5100's before I switched to 35's. They will fit just fine.
That will work fine. Yes you should do UCA's.can check my post if possible. but want to do a bilstein 6112/5100 level set with 2.2 level setting. then want to keep my stock rims (20x9) and slap on 285/65/20 Toyo OC AT3. is that possible with stock rim? and also will i need UCAs for that set up with those tires?
ok thank you! i will get UCAs as well then, any brand recommendations for those? also do you think that this is a good set up for what im looking for? definitely wanted to go with a strut/coil/shock level over a spacer or puck level any day from what ive read but good choice? (if you were able to look at my post) and last question is with the Bilstein level kit, and thoughts size tires on stock rims... will there be any rub you think? or will i unfortunately have to do wheel spacers for the offset? (which i heard is terrible to do.)That will work fine. Yes you should do UCA's.
