white daytime running lights
dually21blk
Not sure if this is the proper forum but I'm looking to see if anyone can give me an answer .
I have 2021 Ram 3500 6.7L I6 Cummins HO Diesel with white daytime running lights and I want to make them Amber.
Does anyone have any in sight on how to make my daytime running lights from White to Amber?
You can use the Tazer, or AlfaOBD to switch your DRL to be your Amber running lights. If you are talking about the white LED strip above and below headlights those arent DRLs
Thanks for your comments but can you give me more about the Tazer? Is there a model # or can you refer me to a website where I can find how to buy.
Thanks
The HDs are a little different than the 5th gen 1500s. Your upper and lower LED strips (signature lighting) are white only, and don’t serve as the turn signals like the 1500 limited upper strip or 1500 Laramie lower strip. Your turn signals are separate, underneath-
You’ll need to use AlfaOBD to do what you want to do, because the tazer for HD Rams isn’t capable of turning off the signature lighting. Basically, all you need to do is disable signature lighting, and change the DRL location from low beams to turn signals.
