Where to mount 2 somewhat compact amps?? Quad cab 1500 big horn
WRS087
I am going to be installing my entire sound system next week. The includes a pac amp pro to keep my factory big horn uconnect screen. A anc bypass harness, new speakers all around, and 2 jl 10s under the seat. Since I am putting 2 subs under the rear seat, I’ll lose most of that room.
The amps I’m using are the Rockford t400 and t750 which are pretty small and compact. I was thinking of mounting them under the passenger seat. Where else have you guys mounted subs with a similar set up?
I mounted mine on the rear of the cab. I removed the single seat in the back. Mine is crew cab but it should be the same.
Yes I put 3/4" mdf wood but later I went back over it with sound deadener to keep it from rattling
