Wheels and tires
Ram79hemi
Rhode Island
Okay, I have a 2019 Laramie with 18" stock wheels and tires . I purchased from ebay a set of 20" stock wheels and tires with tire pressure sensors in them already . Do I have to take my truck to the dealer to reset the system?
Do they have to calibrate my speedometer as well?
As long as they are oem sensors then you are good. From what I am being told as long as it’s a stock size the dealership can calibrate it seems for a cost.
Okay thanks, even though they are stock tires I'm still going to have to calibrate the speed sensor?
I’m feeling that if your truck came with 18” wheels like mine and you swap to an oem larger size, it needs to be. Now of course if you were keeping everything the same height / width wise then it wouldn’t adversely affect it.
By the way, which 20” wheels did you go with ?
Trying to send picture ,but it's not working they are the 20" polished ones with the granite crystal inbetween. They have the falken at tires.
Just to be sure which one are you referring to please ?
What will you do with your Laramie wheels / tires ?
Probably just sell them on Craigslist. They only have like 5000 miles on them , not a single scratch on any of the rims.
May want to hold onto them for winter use or in a case of emergency break glass kind of deal.
Yeah, or I could sell them and buy more stuff for my truck.
Lol you did not hear that from meeeeeeeeeeeee.
Yea, I'm not sure this is true. The overall diameter of the two OEM setups is the same. So you shouldn't need to recalibrate to accommodate just a change in rim diameter.
Sent from my SM-G960U1 using Tapatalk
