Wheel offsets vs backspacing
btman897
I’ve got the stock 20x9 wheels with 33” Nitto Ridge Grapplers currently on my stock suspension 2019 Ram 1500. I’m wanting to get new wheels and I’m not savvy on wheel lingo but would a -24 offset with 4.6 backspacing on 20x10 wheels work fine on the stock set up without any rubbing? Or would I need to do at minimum a 2” lift to prevent having to trim anything? Thanks in advance! I would like a little more slightly aggressive stance than what I’ve got currently. Any advice or tips would also be appreciated.
From what I know and after using the offset calculator you will stick out 1.69 further out than currently. I maybe wrong....
use this..
If you’re not going taller/bigger wheel and you’re just wanting wider look, Why not save money on the new rims and get a spacer?
