What seems to be a low rumble
Nordyke
When I drive my truck now there seems to be a low rumble that emanates either from the transfer case or one of the front driveshaft. Has anyone else encountered this? I shift a neutral, no change in timber or volume in all four settings to wheel four-wheel high for real low and auto all sounds the same leaning towards transfer case, but a little bewildered as to the origin.
Inspect the tires. Check if any wheel weights are missing. I assume you've already checked for low tire pressures(?).
