michaeld2470
- Dec 12, 2020
Looks like where the bed lights mount. You might add a signature and share some details about your truck configuration. Welcome!Anyone know what the tall hole pictured below in the bed is used for? I’m also looking to purchase a cover for that hole as it was missing when I purchased the truck if anyone knows where to buy one. Thanks!
Thanks! Just purchased a 2019 Ram 1500 Crew Cab Laramie. 6’ 4” bed.Looks like where the bed lights mount. You might add a signature and share some details about your truck configuration. Welcome!
As you've probably already read, that opening is for the bed lights. Trucks not equipped from the factory with the bed lighting system leave with the plastic cover installed in that spot. Your dealer should supply one to you.Anyone know what the tall hole pictured below in the bed is used for? I’m also looking to purchase a cover for that hole as it was missing when I purchased the truck if anyone knows where to buy one. Thanks!
Did you 3D print that ?Mine were missing so I did something similar.
Nope, just an Amazon purchase.Did you 3D print that ?
Oh cool. Share a link if you could ?Nope, just an Amazon purchase.
Cool thanks. I thought it was made for the truck it fit so well in the hole.
It is a little short such that I can't get screws in the bottom. I'm going to just try being careful plugging stuff in and out (won't be that often). If necessary, I'll have to put a little backing plate behind the bottom holes.Cool thanks. I thought it was made for the truck it fit so well in the hole.
