What is this hole in the bed?
michaeld2470
Anyone know what the tall hole pictured below in the bed is used for? I’m also looking to purchase a cover for that hole as it was missing when I purchased the truck if anyone knows where to buy one. Thanks!
Looks like where the bed lights mount. You might add a signature and share some details about your truck configuration. Welcome!
Thanks! Just purchased a 2019 Ram 1500 Crew Cab Laramie. 6’ 4” bed.
Get the plastic cover you don’t have the lights
Just to clean up any loose ends, get it from the Ram Dealer
As you've probably already read, that opening is for the bed lights. Trucks not equipped from the factory with the bed lighting system leave with the plastic cover installed in that spot. Your dealer should supply one to you.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044313 miles.
I used it to mount a 12V cig plug. I use it to run my 12V fridge or charge my lithium battery pack when driving. I wired it from the 12V wire at the trailer plug.c81ea1b3-2ab8-42b0-9f55-0293f7172263.jpeg
Cool thanks. I thought it was made for the truck it fit so well in the hole.
It is a little short such that I can't get screws in the bottom. I'm going to just try being careful plugging stuff in and out (won't be that often). If necessary, I'll have to put a little backing plate behind the bottom holes.
