ArmyRetCW3
My first post here.
I recently bought a used 2021 RAM 1500 Limited with 3,650 miles. It did not have the original OEM tires = 275/55R20 113 BSW All Season Tires, with 20-inch x 9.0-inch polished wheels with inserts. I got this information from the MSRP sticker. It calls for a 36 PSI cold, for the OEM tires.
The tires on the truck are:
TOYO R/T OPEN COUNTRY - Tubeless Steel Belted Radial M+S 33x12.50 R20LT 114Q 10 P.R. - DOT 7 3 A 9 NKM0621 OPRT -B-A03
Never exceed 275??? (40 PSI) Load range E – Max Load 1180 kg (2600 lbs.) AT 450 KPq (65 PSI) cold
I went to the local Goodyear tire dealer about the correct PSI for every day driving, with no off-road driving. He recommended to keep it at around 38 PSI, which is within the 40-65 PSI. However, I also sent an email to the TOYO tire company thru their web site and the response was to keep it at 55 PSI. Still within the limits but a bit higher than the 38 PSI from the Goodyear guy.
What is the correct PSI for these tires? Thank you in advance.
