Weird problem with Front Driver's Left Turn signal PLEASE HELP ME!
tomwid12
Hi guys, new to the forums, been a lurker for a very long time. I have this weird problem with my mirror blinker blinking fast and I have a turn signal light out message on the dash, but my turn signals front and back WORK FINE. They don't even blink fast? What's weird is that I have 2 codes in alphaobd. These are the 2 codes I'm getting. Can someone please help me? I did a search on google and on here and nothing is popping up. Thank you.
31RamIt
Check all your wiring to the front left turn signal. Could have a short somewhere.
Skg74
Did you upgrade to LED headlamps? I’m also dealing with the same issue.
Skg74
Search LED headlights, should bring up a post with me and another guy talking about it.
tomwid12
I checked all of the wires with a tester and even the relay and it's all getting power. Not sure what's going on it's driving me nuts.
tomwid12
Also the truck came with the standard LED lights, didn't need to upgrade.
Skg74
If that’s the case sounds like a dealer visit. I upgraded mine from the halogen to OEM LED.
crusher
st-jean quebec canada
check your 3rd brake lights to see if they are working proprelly, had a similar problem on my previous ram, it was a 4th gen so maybe its not like that anymore, but it was my 3rd brake light that cause the fault message even though it says turn signal
Skg74
Was the bulb burned out, or more so an electrical issue?
