Waze/Nav volume too low on CarPlay
Epfireman
It’s seems something has changed in my Ram nav settings. When in CarPlay the nav volume use to be the same loudness as stereo. But now my Waze app is way low and barely audible. The phone volume is all the way up and volume in waze app is all the way up too.. but you can’t barely hear waze unless it’s the only thing playing... I’ve heard a temp fix is to turn volume up on head unit when the app is giving directions but will reset to the lower volume when the vehicle is shut off .. I’m gonna try this today to confirm... anyone got any 411 or having the same problem.. it seems this change occurred when I got the update for the drone /rumble sound in the active noise cancelling update a month ago... Ramcare ???
Check the settings in the Waze App. I think there is a volume setting in there.
Your music and nav have two different volumes. The only way I’ve seen to adjust it is when the nav is giving a direction. As the nav is giving you a direction you have a short period of time to adjust the volume on your radio. I usually use the steering wheel buttons. When nav kicks in it will use that volume and then the previous volume for music. Hopefully that makes sense
^ yup what he said, while the nav is talking, turn the dial up!
