Water collects under the grille
Kiwiaudio
Ohio
Under the grille on my '24 there is a trough area the full width without a drain hole. Water just fills this area up. Ideas ?
Darksteel165
Massachusetts
I use a leaf blower to blow it out or just drive down the block and back.
I use a leaf blower also. It's crazy how much water builds up there lol. Even if a leaf blower it takes several passes to get it empty.
I wonder if a drain hole could be added, or if the plastic trim is too close to the bumper to matter.
I had to add my own drain holes under my battery because there was a pool of water and ice during the winter just sitting there with 0 drain holes. With all the leaks and lack of drain holes in these trucks have you would think Ram never thought they would get wet.
Kiwiaudio
Ohio
Yes, the leaf blower is how i first found the issue. Surprised me how wet i got when it all blasted out of there :)
Drive and the wind will blow it out
