MidnightExpre$$
I want to add lights in the back of my truck. I want them to go on when in reverse, but I also want them to go on with a switch so I can use them while the truck is still in park as well. Actually, I would settle for just the switch activation if it cant be done to operate with reverse and switch. My BigHorn has the switch panel under the 12inch display. It only has 4 switches in use. Would I be able to change to this 5 switch group (picture below) and use the additional switch for the lights I add?
@Jimmy07
@Jimmy07
