I have a Viofo A329 dashcam and wish to tap into my 2024 Ram 1500 Laramie fusebox so can use the parking feature. I will need a constant power fuse and a auxillary powered fuse. Which specific fuse numbers should I tap into. There is a wire from the dashcam for constant power, a wire for auxillary power and of course a ground that will be connected to a bolt. Has anyone done this? If so, what fuse numbers did you tap into. Thx in advance. Tom
