Loving the large Moonroof and have it open quite a bit now that we are getting temps in the 60's. I notice to get air flow in the cab when the moonroof is open, i need to open the back window or run the fan. If I run the fan then I have to have a temp setting.
Is there a way to have vents open with out the fan running? or is there a setting for the HVAC system i need to check? Be nice that when the moonroof is open, air freely flows from the dash vents.
Advise?
Advise?
